sofoklis Posted December 25, 2014 Share Posted December 25, 2014 Guys I just bought a used pod HD 500 and I already have problems with the the POD HD edit software. Although windows and this monkey thing recognize the device when I run the POD HD edit software the message "Could not detect a POD HD connected to your computer. POD HD edit will run in offline mode". I tried 3 different versions of POD HD edit uninstall and reisntall the drivers multiple times and with different order...nothing changes... Any ideas that could help? Quote Link to comment Share on other sites More sharing options...
alienux Posted December 25, 2014 Share Posted December 25, 2014 Try different USB cables and/or different USB ports. Even if they seem to work normally with other devices, many users have had luck just trying different ports or cables. Also, if you're using a USB hub, connect directly to the computer instead. The PODs often don't do well with hubs. Quote Link to comment Share on other sites More sharing options...
sofoklis Posted December 26, 2014 Author Share Posted December 26, 2014 Updating HD edit from the monkey thing solved the problem. Quote Link to comment Share on other sites More sharing options...
