LarryWilliams Posted December 28, 2014 Share Posted December 28, 2014 First, this was working just fine for the last year. I did the firmware update on the 500, then didn't turn anything for a couple months to even try it. Have NOT update the JTV to 2.10. The POD models change just fine, but the guitar models are not changing with it like it was? So I fired up Workbench to see what it said in the software. In the mixer section, the model changes are there the way they were before. Was there something to do in the POD after the update? I did calibrate the Exp Pedal......but that is all that I did. I need help quickly, hoping to use this on a New Year's gig. Quote Link to comment Share on other sites More sharing options...
silverhead Posted December 29, 2014 Share Posted December 29, 2014 In the Variax section of the editor (either Pod directly or HD500 Edit) make sure you are selecting a specific model, rather than the 'Don't Force' setting. Also, make sure the Setup menu for the Variax specifies Preset rather than Global. Quote Link to comment Share on other sites More sharing options...
LarryWilliams Posted December 29, 2014 Author Share Posted December 29, 2014 I will check those, but, as I said, it WAS working before the POD firmware update. So I am wondering if there is something to be set with the hardware switches on the POD LCD panel. Quote Link to comment Share on other sites More sharing options...
