Dl4 Dead Again
10 replies to this topic
#1 sm8691
sm8691
  • 4 posts
  • Registered Products:1
Posted 23 June 2013 - 01:14 PM
I have had this DL4 for 6 months and it just quit working. I did a reset and it worked for a few days and now it has died again and I can't get the reset to work. What are my options?
#2 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 9052 posts
  • LocationMinneapolis, MN
  • Registered Products:2
Posted 23 June 2013 - 01:59 PM
Did you buy the DL4 new from an authorized dealer? If so the warranty is one year, and you should be able to have your repaired under warranty.
#3 sm8691
sm8691
  • 4 posts
Posted 24 June 2013 - 03:19 AM
Bought it from Amazon
  • -1
#4 toneman2121
toneman2121
    Guru
  • PipPipPipPipPip
  • 2788 posts
  • Locationphilly
Posted 24 June 2013 - 03:29 AM
check the power supply. that's all i can think of
I'M SO HAPPY!
#5 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 9052 posts
Posted 24 June 2013 - 05:59 AM
Was it new when you bought it through Amazon? If so, getting a copy of your receipt is easy - Amazon keeps records of all your purchases. Once you have that, it's a matter of contacting the service center nearest you.
http://line6.com/service_centers/
#6 sm8691
sm8691
  • 4 posts
Posted 01 September 2013 - 07:54 AM
Took it to a service center and was told they could not find anything wrong. It died on me again today in between sets. Going to try and reset it and probably sell it. I need something that is more dependable.
#7 toneman2121
toneman2121
    Guru
  • PipPipPipPipPip
  • 2788 posts
  • Locationphilly
Posted 01 September 2013 - 10:43 AM
so your going to sell a defective piece of equipment. i hope you'll inform the buyer of the defect
I'M SO HAPPY!
#8 sm8691
sm8691
  • 4 posts
Posted 02 September 2013 - 04:36 AM
The line 6 service center said there is nothing wrong with it.
  • -1
#9 toneman2121
toneman2121
    Guru
  • PipPipPipPipPip
  • 2788 posts
  • Locationphilly
Posted 02 September 2013 - 05:05 AM
yeah, right
I'M SO HAPPY!
#10 beedoola
beedoola
  • 3 posts
Posted 04 July 2014 - 07:25 PM
Hi.
I've had a good track record with fixing dead DL-4s, I hope I can help.
Usual Disclaimer*** --- I'm not responsible if you mess up your DL-4.
A common issue is the EPROM chip not sitting right in the socket.
You have to take on the back plate, you should see the little chip in the socket, on the PCB. It should say "V1.3" or something like that on the sticker.
Give it a press to see if it can do any further into the socket. Don't apply too much pressure.
Don't put the back plate on, leave it off.
Try the hard reset again - A + D while powering, or better yet; have the power connected and then insert the Mono Input. Try that a few times. If that doesn't work:
Get a small flat head screwdriver - I mean really small, what someone would use for repairing watches.
You'll need to take the EPROM chip out of the socket, inspect it, maybe clean the socket with contact cleaner, and then reinsert the chip.
In the upper right and bottom left of the socket, you'll see small openings. Put the screw driver there and slowly work at each corner of the chip, in the locations mentioned, to pry it out. BE VERY GENTLE.
Try what I said about and then reinsert the chip. Try the hard reset.
Sometimes I had to try it a few times but that has often done the trick.
If that doesn't work, it may be a power issue which takes more troubleshooting as well as taking the pedal apart and having a Digital Multimeter to test the voltages.
I hope you resurrect it!1
#11 AJavierZ23
AJavierZ23
  • 1 posts
Posted 27 March 2017 - 02:25 PM
Hello, my DL4 is dead, I have purchased this item almost a year ago by amazon. Still has warranty. I need technical support in Ecuador. Help me please.
