Jtv-59 Unwanted Harmonics
harmonics accidental unwanted
12 replies to this topic
#1 mrsqueaky
mrsqueaky
  • 9 posts
Posted 24 June 2013 - 02:55 AM
I seem to have an issue with the 'A' and 'D' string ringing out. I noticed the problem when I was doing some finger picking on the top 3 strings in an alternate tuning. For example, when picking the 'G' string at the 2nd fret (producing an 'A') the 'A' string rings out at the same time in sympathy. The problem is if you're in an alternate tuning e.g. one semi-tone down, then this is very discordant. It happens with several strings in various places on the neck.
I have raised it as an issue with Line 6 and I'm now awaiting a reply. Has anyone else found a solution to this problem?
Actually, I've just realised. You would expect that if the guitar is in alternate tuning mode then any strings that produced a note (even if resonating in sympathy with another string) would be in the alternate tuning. e.g. an open 'A' string would produce an 'Ab' if detuned by a semi-tone in software. However it seems to produce an 'A'. I'll need to verify when I get home tonight but I'm sure that's what it is doing. Very strange.
#2 toneman2121
toneman2121
    Guru
  • PipPipPipPipPip
  • 2788 posts
  • Locationphilly
  • Registered Products:1
Posted 24 June 2013 - 03:23 AM
if the strings are old replac'em. if you can reload/rese :)t/reflash firmware/software, do that :)
I'M SO HAPPY!
#3 snhirsch
snhirsch
    Gear Head
  • PipPipPip
  • 616 posts
  • LocationBurlington, VT USA
  • Registered Products:3
Posted 24 June 2013 - 04:00 AM
Are you sure you aren't hearing the acoustic vibration of the A string directly - in addition to the amplified and pitch-shifted tone?  I'm always surprised at how even small amounts of "leaked" sound from the strings themselves can be audible above the amplification.  Even with headphones on I've been fooled by this a number of times.
40 years of Rock-n-Roll and proud of it!
PRS Custom 24 (1990)
James Tyler Variax JTV-69(k) w/ Strat Neck
Fender / Roland GC-1 Guitar
Boss GP-10 13-pin Processor
Antares ATG-1 Autotune Pedal
Fender Mustang III.v2 Modeling Amp
#4 mrsqueaky
mrsqueaky
  • 9 posts
Posted 24 June 2013 - 04:35 AM
Done and done. No difference unfortunately
#5 toneman2121
toneman2121
    Guru
  • PipPipPipPipPip
  • 2788 posts
  • Locationphilly
Posted 24 June 2013 - 04:37 AM
that's posibool
I'M SO HAPPY!
#6 mrsqueaky
mrsqueaky
  • 9 posts
Posted 24 June 2013 - 04:38 AM
No, It's definitely coming from the amp rather than directly from the strings. I can hear a certain amount of sounds from the strings but this is as loud as the amp. Also, the longer you let it go on the worse it gets almost like feedback.
#7 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 16061 posts
  • LocationOntario, Canada
  • Registered Products:16
Posted 24 June 2013 - 04:40 AM
Try recording a sample. Compare the recorded sound to what you hear when playing live. Does the symptom exist in the recording?
.... John Lennon
#8 mrsqueaky
mrsqueaky
  • 9 posts
Posted 24 June 2013 - 06:43 AM
Good idea. I'll try that tonight.
Can you post sound samples on here? Might be easier if people can hear what I'm hearing.
#9 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 16061 posts
Posted 24 June 2013 - 06:48 AM
Yes, you can post sound samples. But you'll be able to interpret the test yourself. If you hear the symptom in the recording then there's an issue to troubleshoot; if the symptom is not apparent in the recording then you know it comes from the inherent string resonance that you hear when playing live but is not coming from the processed output of the guitar and will not be audible to an audience or in a recording.
.... John Lennon
#10 nikoniablue
nikoniablue
    Iknowathingortwo
  • PipPip
  • 102 posts
  • LocationSt Albans, England
  • Registered Products:2
Posted 24 June 2013 - 09:25 AM
That is absolutely the only way to tell.  I've been amazed at how resonant the JTV-59 is.  I have an old Variax 300 as well and playing that in an open tuning through an amp at moderate volume I can't hear the acoustic sound at all.  Change to the JTV-59 and you'd swear something was wrong - sometimes it sounds like an out of tune 12 string.  Even in headphones it seems to break through a bit.  But record it (or wear really well sealed headphones) and it's fine! I'll be interested to hear how you, MrSqueaky, get on.
#11 mrsqueaky
mrsqueaky
  • 9 posts
Posted 25 June 2013 - 10:26 AM
How do I record the Variax on my pc? It recognises it via the USB port as I have updated the software but I can't get any sound into my pc. I've been using Pod Farm but no joy.
#12 toneman2121
toneman2121
    Guru
  • PipPipPipPipPip
  • 2788 posts
  • Locationphilly
Posted 25 June 2013 - 10:42 AM
look, i'm lacking in knowledge in recording, but i think you need a recording program. or is that what pod farm is ?
I'M SO HAPPY!
#13 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 16061 posts
Posted 25 June 2013 - 12:18 PM
You need a recording program. Pod Farm is not one. The simplest in your case, I think, would be Riffworks. There's a free version here:
http://www.sonomawireworks.com/T4/
.... John Lennon
