Using a Digitech pedal with Amplifi as an amp only
muzikmark
What is the best setting to use on an Amplifi amp with an alternative effects board?
I have a Digitech RP500 and would sometimes like to use this with my very portable Amplifi 75.
What is the best setting to use on the amp for this?
      Thanx, Mark
As long as you're using a relatively clean amp model on the Amplifi, you should be fine to use it with the RP500 the same way you would use any other amp. Just turn off all the effects in the tone you're using on the Amplifi.
