rchibnik Posted June 24, 2013 Share Posted June 24, 2013 I usually connect my HD500 into my DT25 via L6Link. Last night I brought just the pedal to a jam figuring I would plug into the PA but can't get any output out of either of the 1/4" output jacks. HD500 is definately getting signal from the guitar via VDI (tuner works) and the 1/4" cable to the PA definitely works (tested it with the 1/4" jack on the guitar.) Tried it again this morning using my PA with the same results, either through 1/4" output jacks or the Balanced output without getting anything from the PA (again, VDI to HD500 tested ok - tuner works) and 1/4" cable from guitar to PA gives output. I couldnt find anything in the output setting of systems, or the PIlots guide suggesting that an output setting be made. I suppose its possible that the HD500 is broken, but kinda doubt it - I figure its got to be some setting that I'm missing that will be obvious to someone here. Thanks in advance for your help Quote Link to comment Share on other sites More sharing options...
silverhead Posted June 24, 2013 Share Posted June 24, 2013 Check the 1/4" out switch on top of your POD HD500. Make sure it is set fully to either AMP or LINE (in your case you probably want LINE). I chased the identical symptom on my Pod X3 Live for a few hours years ago before I noticed that this switch had been bumped into the middle position, where it surprisingly acted as a MUTE switch because neither AMP nor LINE was engaged. I was more careful vacuuming the top of the device thereafter. Just a guess - I don't know if the same thing is true on the HD500. Quote Link to comment Share on other sites More sharing options...
rchibnik Posted June 25, 2013 Author Share Posted June 25, 2013 I did check the switch but it had no effect. With a little more fiddling I got it to work - near as I can tell, the volume settings were too low. I guess I could be more lame - could have forgot to plug it in. Thanks for your help. 1 Quote Link to comment Share on other sites More sharing options...
