scarhand Posted January 25, 2015 Share Posted January 25, 2015 I was experiencing this issue with an old GX I had. About every 3-4 seconds I can hear a single crack/pop/zap (whatever you wanna call it) noise in the playback. It is very annoying and ruins any chance of making a decent recording. So I went ahead and bought a UX1 from amazon, thinking that would solve the issue. It didn't. I still get the exact same single crack/pop noise every 3-4 seconds with the UX1 as well. I am feeling like I wasted money on both of these devices now. How do I fix this, if it is even possible? I've tried different USB ports, different headphones, no headphones, and everything I could think of. No matter what it just keeps happening. Quote Link to comment Share on other sites More sharing options...
Brazzy Posted January 26, 2015 Share Posted January 26, 2015 You should look into adjusting the buffer in the "Line 6 Audio Midi Devices" settings. This helped me once with that problem. You may also try uninstalling everything related to the software your using with "line 6 uninstaller", restart the computer and reinstall it all and restart the computer. Obviously, do not throw away your GX. The one I have from '08 is still going strong. Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted January 26, 2015 Share Posted January 26, 2015 Since you mention 'playback', you must be reocrding the signal? Check your buffer setting in your DAW. Quote Link to comment Share on other sites More sharing options...
Brazzy Posted January 26, 2015 Share Posted January 26, 2015 Since you mention 'playback', you must be reocrding the signal? Check your buffer setting in your DAW. True, good point. I use Ableton as a slave to RiffWorks. I first set the "Line 6 Audio" buffer setting to what I want and then I open RiffWorks, let that start and then open Ableton. What I see happening is Ableton follows suit so in effect I don't need to set the DAW. I suppose it depends on which DAW your using. It's possible you need to check both to be sure they're the same. Quote Link to comment Share on other sites More sharing options...
