vikingguitar Posted February 4, 2015 Share Posted February 4, 2015 ATTENTION AUDIO NERDS. I NEED HELP. I'm noticing that I'm getting a quality difference between recording direct from POD Farm, and recording dry and then using the VST. It's manifesting as a noticeable buzzing noise when using the VST. I'm not sure what's causing this. My DAW is Reaper. I'm recording new media as 64bit WAV with a project sample rate of 192k. I initially thought that this was just computer/monitor interference with my guitar pickups, but that doesn't make sense in this context. Here's a WAV file to demonstrate what's happening. I recorded two lines simultaneously; one wet and one dry. The settings on the VST instance of POD Farm are identical to what I was playing through for the wet sound. There is no difference in volume or other effects/VSTs between the two tracks. The WAV file switches between the wet/VST sound as follows: http://goo.gl/CiKYmM Wet: 0:00 - 0:07VST: 0:07 - 0:14Wet: 0:14 - 0:20VST: 0:20 - 0:31 Quote Link to comment Share on other sites More sharing options...
vikingguitar Posted February 4, 2015 Author Share Posted February 4, 2015 ...aaaaand nevermind. I figured it out. Even though REAPER was set to record at a high sample rate, my audio driver for the UX2 still was sending a 44k signal. Changed that to 48k and everything's good now! Quote Link to comment Share on other sites More sharing options...
Triryche Posted February 4, 2015 Share Posted February 4, 2015 Who you calling nerds? I prefer geek!! Glad you got it sorted quickly!! Quote Link to comment Share on other sites More sharing options...
