robertmcollins3 Posted February 7, 2015 Share Posted February 7, 2015 I'm sure this is simple, as I'm just trying to assign the amp drive to be controlled by the volume pedal. I set its minimum and maximum values, but instead of the volume pedal panning between those, it just goes back to zero again when I move the volume pedal. All I have in the chain right now is just the amp and a volume pedal. Quote Link to comment Share on other sites More sharing options...
arislaf Posted February 7, 2015 Share Posted February 7, 2015 Remove the volume pedal, you don't need it. Then go to the controllers panel and assign drive on the pedal. 1 Quote Link to comment Share on other sites More sharing options...
brue58ski Posted February 7, 2015 Share Posted February 7, 2015 Do you have HD Edit on your computer? Quote Link to comment Share on other sites More sharing options...
pithagoras Posted February 7, 2015 Share Posted February 7, 2015 Are you sure you choose the correct assigned exp pedal (exp1 or exp2) ? Quote Link to comment Share on other sites More sharing options...
