Running My M13 Into Amp And Into Pa
5 replies to this topic
#1 thirtyplus
thirtyplus
  • 8 posts
  • Registered Products:1
Posted 28 June 2013 - 08:10 AM
I play in a rock four piece and we rarely mic up amps or anything except the bass drum and snare. At a normal gig I run my M13 using the 4 cable method into my fender blues deville 410. Occassionally we play in venues where the venue owners want to put us in to the house PA also to spread the sound around the venue. The position I like to put the mic at for my amp is 4-6 inches from the grille. This makes it tight on some stages.
I was hoping that I could use the right side output on the M13 directly into my pocket pod (using amp modelling with no effects on the pocket pod) and from there DI into the PA from the direct out on the pocket POD.
On the M13 I assume I will have to run a jumper from the right side FX send to the right side FX return to enable the stereo output. But in theory this should not be a problem.
Can anyone warn me in advance of any issues I may encounter here?
#2 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 8664 posts
  • LocationMinneapolis, MN
  • Registered Products:2
Posted 28 June 2013 - 08:24 AM
It depends on what effects you use after the loop, but you'll most like run into an issue. The thing that you'll run into is that most of the effects on the M13 aren't true stereo. Even though they take a stereo input, they sum the input, process the signal, and then output a stereo signal. So the signal from the DeVille's preamp will be sent to the Pocket POD. In other words, you won't maintain a stereo split throughout your rig.
If you could ditch the 4-cable method on the nights you need to go direct, you could plug the Pocket POD into the M13's right output, and you could do what you want to do. But if you're depending on the DeVille for you distortion, that might not be an option.
#3 thirtyplus
thirtyplus
  • 8 posts
Posted 28 June 2013 - 08:28 AM
I am hoping not to use any stereo effects. I am hoping that I can just have two outputs without using a mic in front of my amp on stage.
When you say the effects are not stereo are you saying that they will only come through on the mono output and not the stereo output?
#4 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 8664 posts
Posted 28 June 2013 - 08:36 AM
I'm saying the signal going to the Pocket POD will contain audio from your amp's preamp, and because of that, the Pocket POD will most likely not sound the way you want it to.
#5 thirtyplus
thirtyplus
  • 8 posts
Posted 28 June 2013 - 08:37 AM
So I don't need the pocket pod for the amp modelling as I have the sound of my amp from the 4CM. I just need to DI the right side M13 output?...
#6 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 8664 posts
Posted 28 June 2013 - 08:44 AM
Nope... That won't work either. Sending the preamp signal from your amp direct to the board would likely sound, well, not very good.
Essentially, when you choose to use the 4-cable method, you're limiting what you can do with the M13's signal splitting capabilities. Micing your amp is still probably the best thing you can do. I'd say if the distance between the mic and grille is what's causing problems, you might want to look into the Sennheiser E609. You can drape it over the front of your amp, and it's very low profile. It essentially doesn't take up any room on stage.
