357mag Posted February 8, 2015 Share Posted February 8, 2015 Can a pickup booster pedal or say a graphic equalizer be used in the effects loop of the POD XT Pro to help shape my sound further? Quote Link to comment Share on other sites More sharing options...
Mr_Arkadin Posted February 8, 2015 Share Posted February 8, 2015 To be honest, where the loop is in the signal chain makes it fairly useless. It appears just before the analogue outputs, so you may as well stick whatever effect on the main output. Sure you could use a graphic EQ after the Pod, but stomp effects like a booster pedal I would probably place between the guitar and Pod input. Quote Link to comment Share on other sites More sharing options...
357mag Posted February 9, 2015 Author Share Posted February 9, 2015 When you say "after the Pod" or "on the main output" what do you mean? Bear in mind I just plug my guitar into the Pod's input and play through headphones. No amplifier is being used. Quote Link to comment Share on other sites More sharing options...
Mr_Arkadin Posted February 9, 2015 Share Posted February 9, 2015 In that case yes you would need to use the loop to hear anything in your headphones. Quote Link to comment Share on other sites More sharing options...
