JTV - patch change toggle within HD500x patch... Possible?
jtv hd500x patch toggle
5 replies to this topic
#1 big_vin
big_vin
  • 5 posts
  • Registered Products:4
Posted 09 February 2015 - 12:29 AM
I have a JTV69 and I'm looking to buy an Hd500x. In anticipation I've already downloaded the editing software for the Hd500x so I'm familiarising myself with way it works.
I know i can assign a foot switch to switch FX block in and out of the signal chain and that i can assign more than one FX block to a switch. Does anyone know if its possible to assign a foot switch to change a JTV patch in the same manner? I know that each patch within the Hd500x can have Variax patch assigned to it but it would be very helpful if it were possible to toggle between 2 sounds within an Hd500x patch - e.g. An acoustic and an electric... preferably using the same foot switch to switch in/out multiple fx blocks at the same time.
For example if I wanted to play "Pinball Wizard" by The Who, I would need an acoustic sound with quite a lot of compression and a Hi Pass Filter but no 'amp' sound... Then for the chorus it would need and electric sound, different compression, EQ etc., and a 'Hi Watt' or similar...
I know i could use the Mag pickups and an acoustic sound on the variax and go between them with the expression pedal but i want to use the modeled sounds.
As far as i am aware, the variax changes patches using a MIDI protocol down the VDI cable... I cant see that this would be too difficult to implement with software.
I hope i've explained myself - and that i havnt asked a stupid question...
Vin
Xxx
#2 jandrio
jandrio
    Power User
  • PipPipPipPip
  • 1254 posts
  • Registered Products:5
Posted 09 February 2015 - 02:26 AM
no u cannot toggle between 2 different JTV models within a single Hd500x patch, but u can toggle sounds btween different patches.
exception: use dual path with variax+variax mags input settings in one single patch
path A=variax with ANY amp with CH VOL=0 + BYP VOL=100
path B=variax mags with Higway100 amp with CH VOL=100 + BYP VOL=0
assign both amps 2 a single FS.
when both amps r on, only path B will b audible cause CH VOL  of  channel A is zero.
when both amps r off, only path A will b audible cause BYP VOL of channel B is zero.
set mixer 100L + 100R 'n adjust relative levels.
examine attached demo patch.
  • 2
#3 big_vin
big_vin
  • 5 posts
Posted 09 February 2015 - 04:07 AM
Thanks Jandrio,
I suspected as much.
Very useful information for a "work 'round" though. Thanks again for taking the time to explain. I appreciate your time in helping me.
Maybe I'll suggest my 'idea' on the line6 suggestions site - see if it can be included in any firmware updates.
Thanks once again for your help,
Vin
Xxx
  • 1
#4 jandrio
jandrio
    Power User
  • PipPipPipPip
  • 1254 posts
Posted 09 February 2015 - 05:11 AM
u r welcome
  • 1
#5 jmillion
jmillion
  • 30 posts
  • LocationNW Illinois
Posted 24 February 2015 - 02:53 PM
VERY clever. Thanks for the tip and sample patch.
  • 1
#6 jandrio
jandrio
    Power User
  • PipPipPipPip
  • 1254 posts
Posted 25 February 2015 - 02:00 AM
u r welcome...
Also tagged with one or more of these keywords: jtv, hd500x, patch, toggle
