recording a dry input into reason limited and then modifying a patch on the fly using pod farm while looping
reason limited pod farm honing your tone
6 replies to this topic
#1 Marcipicus
Marcipicus
  • 6 posts
  • Registered Products:1
Posted 10 March 2015 - 04:50 PM
Maybe I should post this in a propellerhead forum but I thought I'd try it out here
Is there any way in reason limited and pod farm to do what this guy is doing with pro tools?
In case you aren't following the link he's basically playing a loop of a song he made and trying out all the amp combinations using pod farm while the loop is playing.
I figured out how to record a wet and dry track of the same take and that was pretty cool now I'd just like to learn how to play around with pod farm a bit better.
Please reply if you have any idea of how to do this.
#2 Marcipicus
Marcipicus
  • 6 posts
Posted 10 March 2015 - 04:52 PM
Had trouble putting the link in there so just search for "LINE 6 POD FARM 1/2 (METAL SHOP EXPANSION) to see what he's doing.
#3 fflbrgst
fflbrgst
    Guru
  • PipPipPipPipPip
  • 2557 posts
  • LocationNew England
  • Registered Products:3
Posted 11 March 2015 - 04:35 AM
If you can set your loop in Reason to constantly replay (most DAWs offer this), you can change the PodFarm settings while it is doing this.
  • 1
#4 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 15918 posts
  • LocationOntario, Canada
  • Registered Products:16
Posted 11 March 2015 - 04:41 AM
Reaper definitely does have a loop feature. Select the dry track and section that you want to loop, engage the loop feature, apply the Pod Farm VST to the track, and tweak as playback occurs.
.... John Lennon
#5 Marcipicus
Marcipicus
  • 6 posts
Posted 11 March 2015 - 10:48 AM
Ok thanks for the help
#6 fflbrgst
fflbrgst
    Guru
  • PipPipPipPipPip
  • 2557 posts
Posted 12 March 2015 - 04:41 AM
yes it does, but OP asked about Reason, not reaper.
#7 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 15918 posts
Posted 12 March 2015 - 04:49 AM
Oops... Sorry.
.... John Lennon
Also tagged with one or more of these keywords: reason limited, pod farm, honing your tone
