Tboneous Posted March 18, 2015 Share Posted March 18, 2015 I want to assign 2 fx to one pedal. A tube screamer and a Fuzz face. This is what I want to happen When the footswitch light is on I want the Fuzz Face to be on and the screamer to be off When the footswitch light is off, I want the Fuzz Face to be off and the screamer to be on. How do I do that? Thanx *****EDIT****** Never Mind! I just figured it out! Quote Link to comment Share on other sites More sharing options...
reginaldStjohn Posted March 18, 2015 Share Posted March 18, 2015 In edit or on the unit itself turn the fuzz face on and the screamer off. now assign the desired pedal to both of them. now when you step on the footswitch the one that is on will turn off and the one that is off will turn on. I haven't done this on the device itself for a while but in Line6 Edit program you just select the desired effect and then the footswitch you want to control it with. If you assign the same switch to more than one effect it says "multi" in the edit field indicating that more than one effect is assigned to the same pedal 1 Quote Link to comment Share on other sites More sharing options...
duncann Posted March 18, 2015 Share Posted March 18, 2015 Also, whichever FX is first in the chain is the one that will determine the state of the light. So in your case, you would want the screamer as the second FX. 2 Quote Link to comment Share on other sites More sharing options...
Tboneous Posted March 20, 2015 Author Share Posted March 20, 2015 Also, whichever FX is first in the chain is the one that will determine the state of the light. So in your case, you would want the screamer as the second FX. thats what i figured out! tanx fellas! Quote Link to comment Share on other sites More sharing options...
