rafaarts Posted March 21, 2015 Share Posted March 21, 2015 Hi guys , just got a brand new pod hd500x today ... I was a bit surprised that not all switches are assignable as presets ... Only the bank ones , is there a way to get around this ? Thx Raf Quote Link to comment Share on other sites More sharing options...
silverhead Posted March 21, 2015 Share Posted March 21, 2015 When the FS Mode is set to ABCD (see Setup Menu page 1), the switches labeled A through D recall the 4 presets assigned to the currently active preset bank. You need to use the bank up/down foot switches to select another bank, whereupon the A-D footswitches will select the four presets in that bank. When the FS Mode is set to FS5-8, those same A-D footswitches will turn FX on/off in the current preset, and will not select a new preset. Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted March 22, 2015 Share Posted March 22, 2015 The presets are set up in batches of four, so it makes a lot of sense to have only four pedal options. It also helps to have some pedals available for selecting on/off. But as previously mentioned, you can switch the default. Quote Link to comment Share on other sites More sharing options...
