Flextone Iii And Fbv Mk Ii
1 reply to this topic
#1 tocood
tocood
  • 1 posts
  • Registered Products:2
Posted 04 July 2013 - 04:29 AM
Hello. First go on here. I recently bought a FBV Mk ii for my Flextone iii XL.
Calibrated OK. I need to find out how some switches work - Function 1/2, Stomp and if any switch acts as a lead boost.
Also regarding the volume pedal; can it be swithched off or does it stay on at max. for normal volume?
I've tried the knowledge base but can't find (or can't see) anything.
Thanks.
#2 FlexCapacitor
FlexCapacitor
  • 7 posts
Posted 25 November 2014 - 07:39 PM
Hello, do you still own these products? The FBV MK II is designed to work with many different amps, as well as controlling software. That said, some of the buttons relevance will vary depending on what device the FBV is connected to. The FBV MK II functions as follows when used with the Flextone III series amp:
Function 1 - Press & hold for a few seconds to SAVE your current settings
Function 2 - This button is NA (does nothing) with Flextone 3 series (I can think of a million things I wish it would do!)
Stomp - This button toggles the Compressor on/off, whatever you have it set at on the amp.
The volume pedal is always "active" and there is a toe switch (press volume pedal hard with your toe) to toggle between WAH and VOL function. I believe this pedal can be SAVED in whatever state you currently have it set at. At least I thought that was the case. I should double check that myself...
