G70 / G75 with multiple guitar outputs to multiple destinations?
or8ital
I was interested in possibly purchasing a G70 or G75. I have a guitar with two outputs. One for the standard pickups and one for the piezo. Each needs to go to a different destination. Can I go this with two transmitters and one receiver or do I need two receivers as well?
Thanks.
If you just want one or the other with the G70 or G75 you could use 2 transmitters keeping both on and switch between them using a single receiver. Program a scene for one and another for the other then step on the switch to go between them.
  • 1 month later...
I use three guitars on stage all with dual  (magnetic & piezo) outputs that must work at the same time. Does Line 6 make anything that will run in this environment. Hard to believe there are not more artists out there looking for the same thing. The cost of 6 transmitters and receivers is way out of the scope of possibility.
