Flextone Iii Xl Volume Issues
flextone volume sound oscillation drop
19 replies to this topic
#1 torrevieja
torrevieja
  • 2 posts
  • Registered Products:1
Posted 04 July 2013 - 09:00 AM
Hello,
I've recently bought a Flextone III XL and I'm pretty disapointed.
I have the same problem detailed in this old post (I don't know why Line 6 locked all topics)
http://line6.com/sup.../message/476712
In my case, volume changes coicide when the light of the channel turns off (both in the floorboard and in the amp).
Can it be caused by a digital issue?
I know lots of people had the same problem with this amp. Does anybody knows how to fix it? Technical support is very very far away from my home.
I can't belive Line 6 don't tell me anything but "take it to the technical support". For what I've seen this is a typical issue of this amp.
I would apreciate any help you could give me.
  • 1
#2 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17814 posts
  • LocationClemmons, NC USA
  • Registered Products:17
Posted 08 July 2013 - 05:58 AM
old topics are not locked, they are simply only available for archival reasons as the forum software has changed.
and of course i'm going to tell you to go to a service center with any hardware issues.... sorry but that's the best source of help for you.
#3 fineg1tm
fineg1tm
  • 3 posts
Posted 29 September 2013 - 06:59 AM
I have a Flex III too and there are fluctuations on volume output with selecting an amp.  Some of the existing presets have great volume, but then selection changes cause volume to decrease drastically.  Been baffled by this for some time.
Hello,
#4 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 9063 posts
  • LocationMinneapolis, MN
  • Registered Products:2
Posted 29 September 2013 - 07:03 AM
Well, the levels of the amp models are all different, so when you select different models, the output volume will change. Also, the volume between different presets is likely to be different as well.
#5 arislaf
arislaf
    Power User
  • PipPipPipPip
  • 1819 posts
  • LocationGreece
  • Registered Products:12
Posted 29 September 2013 - 07:08 AM
But, you can adjust the volume of each amp separately, and save them one by one with your personal configurations.
To do the saving, simply press the model knob for 4-5 seconds, until the led of the knob from fixed go to flashing and again to fixed.
Repeat the process to each amp separately.
Before line6 was called line6... they used to do r&d for other companies like alesis + others. and when those customers came to visit the offices of line6 (before it was called line6) and the receptionist needed to warn all the guys who were designing products for other companies (and for themselves... ) who were like 'in the back' the receptionist would announce over a tannoy 'tellephone call for 'fred smith' on line 6' the cunning part was that they only had 5 telephone lines, so it was the secret code for "hide your sh1t the feds are comin'" or "someone's coming, let's hide these PODs that we aren't going to release for another few years so they don't see them"
BEST CABS: www.studiocat.com
#6 fineg1tm
fineg1tm
  • 3 posts
Posted 29 September 2013 - 07:38 AM
Thanks for reply
  • 1
#7 Rockenmon
Rockenmon
  • 1 posts
Posted 02 October 2013 - 07:12 AM
I am having a similar problem with my Flextone III... after 10-20 seconds it drops about half volume. I hit the foot switch channel (same channel) and it brings it back to the volume it was originally set to. It can't be (at least I don't think so) the volume pod because I direct plug the amp out from the stereo outputs in back through the mixer (smokin' tone btw!)... stage volume isn't even on. I did test it using both ways tho, through the amp speakers and direct out and it drops both sources in volume.
I did read on one of the blogs that some one thought it might be a digital problem. is there a way to check that? is there a way to reboot the system and reload it?
Any help would be greatly appreciated, don't want to ditch the amp!
Thanks
Brian
#8 arislaf
arislaf
    Power User
  • PipPipPipPip
  • 1819 posts
  • LocationGreece
Posted 10 October 2013 - 12:41 PM
You can use the line 6 monkey, connect your amp from the midi to your pc and reflash it's firmware / update it.
#9 mp112849
mp112849
  • 8 posts
Posted 09 December 2013 - 01:23 PM
Based on the comment above, I have a question regarding line 6 monkey.  I've been trying to help a friend solve an issue with different patches having different volume levels.  He said that someone suggested reflasing the firmware, which sounds reasonable, but the issue here is that when I install monkey, during the install process, the software asks what device will be connected and the Flextone III is not listed.  What could be the issue?  Does the Flextone III have to be connected during the software installation process?
Also, based on another response in this thread, "But, you can adjust the volume of each amp separately, and save them one by one with your personal configurations.
Repeat the process to each amp separately."  This kind of makes sense, but will it work?
#10 arislaf
arislaf
    Power User
  • PipPipPipPip
  • 1819 posts
  • LocationGreece
Posted 17 December 2013 - 09:12 AM
1) Have your flextone connected before you start the monkey, and during the process.
2)It is working for me, I trust it will work for you.Remember to do it after the reinstalation of the firmware.
#11 mp112849
mp112849
  • 8 posts
Posted 22 December 2013 - 10:50 AM
Here's another interesting problem I'd like to get solved.  When selecting any preset from the A/B/C/D buttons, the volume is at level X (and let's just assume that since the channel volume knob is at MAX, it is theoretically at a maximum value of "10").  If I back down the volume know from it's max pinned position, at about what would be the "8", the volume makes a jump up to a louder level.  That can be something less than the original start value.  When I got the Flextone III, the firmware was at v1.02.  I used Monkey to update the firmware to v1.1, but that did not affect the condition.  What compounds this is the fact that I cannot a bi-directional communication via USB/Midi to my computer, so I really have no way of knowing if the firmware re-flash actually worked.  Using the manual method of determining the firmware version, before the re-flash, powering up while holding the "B" button, the "B" button LED flashed once and the "D" button LED flashed twice.  This told me the firmware version was v1.02.  I then used Monkey to reflash.  Monkey said the reflash was successful, but since the computer could not communicate from the amp midi out to the computer midi in, Monkey could not get the firmware version.  So I repeated the manual method and saw the same LED flashing sequence as when I started with v1.02.  Any ideas on any of this?  Let me know if anyone needs more info.
#12 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17814 posts
Posted 22 December 2013 - 11:47 AM
when you switch to a preset it goes to the saved value regardless of where the knob is...
when you turn the knob it re-reads the position... so if the preset was stored at level "6" and you turn it to "8" from "10" the volume is now louder.
#13 mp112849
mp112849
  • 8 posts
Posted 23 December 2013 - 04:51 AM
OK, RealZap, that makes sense.  Is it possible, just on the amp, to modify and save the volume level of the preset so that its saved volume level is at the MAX level while the channel volume control is at the MAX position?  I'm hoping that then when I back off the channel volume, there will be a linear reduction in volume without the spike at the "8" position.  The thing that puzzles me is why does this happen at the "8" position to begin with?  Why not as soon as you start manipulating the volume knob?
Regarding the issue with not having bi-directional communication between the amp and the computer via the midi ports, do you have any info regarding this?  I did not fully explain the situation, so let me try.  I spent a considerable amount of time trying to get get both Monkey and Line 6 Edit to work.  I kept getting the message about "midi cables not connected, etc, etc", so I assumed there was no connection at all between amp and computer.  As a last resort, I decided to try to flash the firmware anyway just to see.  Upon doing that with Monkey, I saw that all the LEDs on the top amp panel lit up and Monkey actually showed a progress bar that was updating itself.  When that finished, Monkey presented a dialog that said the firmware update was successful and to power down then power up the amp.  That surprised me!  So if I can trust this, it answers a question regarding the amp and computer actually being connected.  It seems that there's a one-way connection and the computer is able to send a MIDI message to the amp and apparently the amp is able to receive the message.  However, either the MIDI out port on the amp is malfunctioning or the MIDI in of the computer is malfunctioning (or both of those are malfunctioning)...  or the midi cable is defective.  I'm using an MIO USB to MIDI cable that's similar to the M-Audio UNO,  Initially, I could not find a way to get Win7 to recognize the MIO MIDI output.  I found a software MIDI mapper that at least allowed the computer to expose the MIO MIDI out device.  At first windows would only expose the Microsoft GS Wavetable Synth, but using the mapper software, I could then select the MIO as my MIDI output device.  Anyway, the real reasons for wanting access to the amp via computer MIDI interface were (1) use Line 6 Edit to rectify the volume issue and (2) update the amp firmware.  I've read somewhere (probably on this forum) the the preferred MIDI interface is the M-Audio UNO.  Would using that interface make the whole process work?  Is it really as simple as that?
#14 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17814 posts
Posted 23 December 2013 - 05:19 AM
you can put the channel volume where you want it, and re-save the preset should be that simple.
it still could be your midi interface... because the amp will update with only one midi port connected successfully.
I'm fairly confident that 2way communication should work. I do recommend the m-audio UNO (and most importantly with the m-audio drivers installed!)
other interfaces have worked of course it's not the only one... but has proven to be very reliable when others weren't working.
i found the UNO to be one of those purchases that have been well worth it... when i really didn't think i'd use it much at all when i bought it.
#15 mp112849
mp112849
  • 8 posts
Posted 23 December 2013 - 07:29 AM
Thanks a lot for the info.  I'll get the UNO and see what happens.  Only reason I got the MIO was that it was available at guitar center.  They used to sell the M-Audio UNO but switched to the MIO.  Probably a better profit margin on the MIO.  They sell it for the same price as the UNO.
Just one more thing.  Regarding the firmware version indicator of the flextone 3.  As I mentioned before, holding the "B" button while powering up should show the current version of firmware with a sequence of blinking LEDS on the channel select buttons.  What should the correct sequence of LED flashes be to indicate v1.1 firmware?  I thought maybe there would be:
"B" button one blink, then "C" button one blink.
The sequence I get is still as if firmware version 1.02 were resident.. I.E, "B" button one blink, then "D" button two blinks.
#16 treyhughes37
treyhughes37
  • 1 posts
Posted 27 March 2014 - 07:48 AM
Did anyone ever find a way to fix the problem mentioned on the beginning of this feed? As shown below.
Hello,
#17 rylanwhite
rylanwhite
  • 1 posts
Posted 08 May 2014 - 12:25 PM
We had an a Line 6 Flextone III come through for repair, customer complaint was that the presets were turning themselves off after about a minute of play, this resulted in a volume drop similar to that experienced by some users on this thread. The preset selection LED would stay illuminated but the actual preset values disappeared.
I flashed the firmware and the problem is now gone, the amp also seems to have more overall volume.
Anyway I can confirm that flashing new firmware can resolve these issues (at least in my case).
#18 TheHero83
TheHero83
  • 1 posts
Posted 10 June 2014 - 11:02 PM
Hi all,
I am having a similar issue, volume cutting to roughly half after a few seconds of play on some patches. This is probably a very silly question but do I need to attach the MIDI in and out of the amp to my PC to get monkey to recognise the amp?
At the moment I am connecting the out of the PC to the in on the amp but it refuses to recognise the Flextone :(
Any help or suggestions appreciated!
#19 johnclegg
johnclegg
  • 1 posts
Posted 16 June 2014 - 12:02 PM
Hi TheHero83
I recently bought a secondhand Flextone Line II and was experiencing problems with intermittent volume, delay etc. changes, so this evening I flashed my amp's flash memory from version 1 to 1.10. I don't know yet if it has improved matters, as I am reading up on issues on this website and now replying to your post, but anyhow this is what I did:-
I registered on Line6.com as a new user.
I already had the recommended M-audio midisport Uno interface so that part was sorted!
I would imagine most PCs need an external midi unit like the Uno to interface to the Flextone III.
The Uno has 3 leads: a USB lead to plug into the PC, a midi lead to plug into the Flextone Midi In socket, and a midi lead to plug into the Flextone Midi Out socket. The Midis are marked appropriately on the Uno plugs and above the Flextone sockets.
I installed the latest M-Audio drivers for my PC running Windows 7 SP1.
I hooked up the Uno's USB plug into the PC's USB port and checked it was now recognised (message temporarliy displayed in the PC display's bottom right tray).
I downloaded Line 6 monkey latest version and installed it as Administrator (right-click on .exe to see option).
I plugged the Uno midi lead saying 'To Midi In' on the plug into the Line 6 amp's Midi In socket.
I plugged the Uno midi lead saying 'To Midi Out' on the plug into the Line 6 amp's Midi Out socket.
I ran Line 6 monkey, which recognised the Flextone immediately.
I selected to update the Flash Memory.
It wanted me to register the product so I entered the serial number on the website (two or three different times), but got 'error 532 could not be validated'.
So I went back to Line 6 monkey and tried again, this time clicking 'Remind Me Later' (to register).
I did not bother backing up the patches in the next step.
Following this the flashing started and progressed smoothly (maybe 5 minutes) and the monkey program confirmed the flash memory is now the latest version 1.10.
HTH
#20 fajahman
fajahman
  • 1 posts
Posted 10 August 2014 - 10:27 PM
Hellow I own a FLEXTONE III   1X12
I turn the amp on and it sounds amazing, but afert 2 minutes it loose all the equalization and preety sound,  i need to change the preset and go back to where i was to make it sound good again,
Help me please! I all ready did the firewire reset and nothing helps
Also tagged with one or more of these keywords: flextone, volume, sound, oscillation, drop
