Cubase And Pod Farm, Track Shows Guitar Audio But Pod Farm Has No Sound
pod farm ux1
7 replies to this topic
#1 deepseahunter
deepseahunter
  • 22 posts
  • Registered Products:1
Posted 25 April 2013 - 06:48 PM
Hello I recently purchased a UX1 went through all the troubles of authentication and everything else, I've been running it through cubase, and finally figured out how to set it all up and got it working and recordably playing through Pod farm 2.55 I then proceeded to accidentally unplug the UX1 while cubase and pod farm were both open, and my computer freaked out and crashed.
Now when I go into cubase and set up all the device ports it shows audio in cubase in the mixer and on the track but won't record audio or play any audio through pod farm 2.5, although Pod farm 2.5 standalone works perfectly fine.
I need lots of help.
My friend who helped me set up the inputs in cubase doesn't have a clue how to get it to work now.
(before I wasnt arming the record and arming the audio, but now I do and it still doesn't get any audio in podfarm vst.)
there are a few pictures to show everything is connected right, and the last shows there is no audio playing in pod farm but its recieving it in cubase.
thank you
DSH
#2 deepseahunter
deepseahunter
  • 22 posts
Posted 25 April 2013 - 08:45 PM
I went into devices and vst connections and changed both the mono 1 and mono 2 device ports to the line 6 ux1 that allowed me to hear the sound again and it also doubles the sound if I leave the device ports of the stereo in there, I believe it fixed the problem, but I was wondering how can I get it to work in stereo instead of psuedo stereo.
thanks again
DSH
#3 deepseahunter
deepseahunter
  • 22 posts
Posted 25 April 2013 - 11:39 PM
correction in one ear I get clean guitar sound and in the other ear I get whatever effects I put on it. i dont know how to fix it.
#4 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17756 posts
  • LocationClemmons, NC USA
  • Registered Products:17
Posted 26 April 2013 - 03:17 AM
first thing i notice you are doing very wrong is that you are using ASIO4ALL.
get rid of that and use the line6 drivers.
  • 1
#5 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7141 posts
  • Registered Products:6
Posted 26 April 2013 - 04:17 AM
+1 to Zap.
You need the use Line6 ASIO.
Run the Monkey to make sure you have the most current drivers.
If you still have problems here's a video you can check to make sure you didn't miss a step.
#6 LewisDunne
LewisDunne
  • 1 posts
Posted 08 September 2016 - 04:01 AM
Hi, apologies for the 3-year bump...
I'm having this exact issue and I don't know what to do. I have the Line 6 GX model. I set everything up as the video suggested. Cubase detects Pod Farm 2 as an insert, and the Pod Farm 2 window pops up when I select it from the list of inserts. But it doesn't detect any sound - it just records the guitar clean.
I have the ASIO GX driver selected.
Since I am totally new to everything here are some screenshots - I'm probably doing something wrong:
#7 johannesleander1
johannesleander1
  • 1 posts
Posted 24 September 2016 - 12:19 PM
LewisDunne, did you ever find a solution to your problem?
I'm having the exact same issue as you, using Line 6 GX and Cubase 5.5 (and Pod Farm 1). The VST seem to modulate the input audio at random but I've never gotten it to record a pre-recorded, clean track. Any help would be appreciated.
#8 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7141 posts
Posted 26 September 2016 - 05:05 AM
There are to versions of POD Farm, standalone and plug-in.
The standalone version you launch outside of the DAW, the plug-in you launch within your DAW.
The standalone can be used to configure what you send to your DAW via the Mixer view.
A typical workflow is to send clean and wet while monitoring the wet, then add the plug-in to the dry post processing.
Also tagged with one or more of these keywords: pod farm, ux1
