TonePort UX8 unbareable output hum
I tried to re-amp using a real amp and my tone port UX8 with no success. All outputs from 3 to 8 (1 and 2 is for my monitors) produces extreme hum or "SHHHHHHHHHHHH" sound when plugging it into my Real guitar amp. I do not even have to send a signal through the output to produce this noise. As soon as the jack is connected the extreme "SHHHHH" starts.
I have tried isolating the problem and found it must be the TonePort itself.
I done the following tests:
1) To eliminate the cable I plugged my guitar into the cable that goes to the amp - NO NOISE.
I immediately unplugged my guitar and plugged it into the TonePort - NOISE
2) I have switched off everything else e.g. Computer, Monitors. Only my tone TonePort was on. SAME NOISE.
Does anyone have ANY other suggestions? I am at the point of getting rid of the TonePort.
Another user experienced the exact same problem in this thread:
http://line6.com/supportarchivenew/thread/91525/
Thanks for the reply. Yes the TonePort is currently plugged into the same outlet / power strip.
I will try putting them on different outlets and see if that makes a difference, but I seriously doubt it as reading through other threads I found that this suggestion did not resolve simmilar issues.
Any other possible causes?
Thanks,
I have tried many different calbe. All calbes tried was plugged into the output to the amp and the noise was there. Then I unplug from output and straight into guitar with NO NOISE. I doubt that it's the calbes.
Could it be because of unbalanced cables or would that not make such a big difference?
NOTE*** The hum or SHHHHHH is REALLY loud.
