rojitolijo2fg Posted April 20, 2015 Share Posted April 20, 2015 Hey guys! is Susan here, ive already installed the Firmware 2,6 in my pod hd 500x and i cant see in the list , the variax set list , and neither the Global EQ , i've already installed two times the Firmware, and in Monkey all its ok, also the model packs , but the global and the variax set list doesnt appear, what you guys think i can do ? Thanks! Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted April 21, 2015 Share Posted April 21, 2015 The variax setlist will not appear if you keep you tones. The global eq is in the unit in the system menu. It will not appear in the software. Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted April 21, 2015 Share Posted April 21, 2015 you won't see the variax setlist name unless you do a global reset Quote Link to comment Share on other sites More sharing options...
rojitolijo2fg Posted May 1, 2015 Author Share Posted May 1, 2015 thank youguys ! i did the global reset , but nothing happens Quote Link to comment Share on other sites More sharing options...
edstar1960 Posted May 1, 2015 Share Posted May 1, 2015 What do you see when you VIEW the System Setup menu? It shows you the flash level in the top right corner which should read 2.6 and it should also have 12 pages with pages 11 and 12 being for the GLOBAL EQ. Also when you installed the FW did you choose to KEEP your patches? If you did choose to keep them then you will NOT see the VARIAX set list in the set list choices - you will just see whatever you originally had on the unit. Quote Link to comment Share on other sites More sharing options...
