string_slinger Posted April 22, 2015 Share Posted April 22, 2015 Hi POD Family! Wanted to ask your help before taking this off to a tech. I have a PD HD Pro X that I bought new about 15 months ago. Up until now I haven't had to use the unbalanced outs (been rolling SPDIF and balanced outputs). Last night I fired up the unbalanced's for the first time (got a Marshall EL84 20/20 for live use), and I found that I'm getting extremely low volume from the one side. Check the amp, check my cables, checked my patches - it's definitely the POD's unbalanced outs that're the problem. I checked them into my audio interface to be sure, and I can see it on the levels. Plus when use the pan controls in POD HD Pro EDIT to test this with a mono amp patch setting, the sound is significantly lower level full right as opposed to full left. Before I have to start looking for a tech, has anyone else experienced this? Is there something unashamedly obvious I may be missing? (been using Line6 gear for 15 years, so I don't think so, but there's always room to learn) Secondly, does anyone know what Line6's warranty policy is after a year of ownership? I sincerely had not used these before yesterday, so I can only assume the problem has been there since I unboxed it. Thanks in advance for any help... Cheers ss Quote Link to comment Share on other sites More sharing options...
silverhead Posted April 22, 2015 Share Posted April 22, 2015 There is an Amp/Line switch that's controls the output level for the unbalanced outs. Have you experimented with it? Quote Link to comment Share on other sites More sharing options...
string_slinger Posted April 23, 2015 Author Share Posted April 23, 2015 Hi! Thanks for reply. I have, yes. The problem is not low output in general, it's that one side is significantly (60%) lower than the other. Output levle on left side is fine, right side seems off. Quote Link to comment Share on other sites More sharing options...
