Dshow Posted April 26, 2015 Share Posted April 26, 2015 On the real marshall jtm45 you can jump the normal and bright channel and gradually blend them togheter. How do you do that in the POD? Do you use the dual channel mode with the normal on one side and the bright on the other? Is this the same as jump the both channels? Thanks Quote Link to comment Share on other sites More sharing options...
Giorgos02 Posted April 27, 2015 Share Posted April 27, 2015 Do you use the dual channel mode with the normal on one side and the bright on the other? Is this the same as jump the both channels? Seems like this is the closest you can get. Theoratically it will work. Quote Link to comment Share on other sites More sharing options...
Dshow Posted April 28, 2015 Author Share Posted April 28, 2015 OK, thanks I'll give it a try Quote Link to comment Share on other sites More sharing options...
