Clean Setting
Maleko
Is the clean setting on the "Spider Jam" supposed to have very little volume or did I get a lemon? Am I not understanding something? Anyone's help will be much appreciated. Mahalo.
If I just turn the Master to around noon both clean models are pretty loud on my Spider Jam. I can also boost it a bit by activating the boost in the settings. Maybe there is something going on. Most of the time with modelers like this the clean volume is relatively low compared to the hi gain models.
Where do have the master volume set?
Aloha Brassy,
Mahalo for the response. I have since experimented with a few external devices and found the Boss "ME-70" helps bring the volume up to normal (normal to me) levels. I'll try your suggestion too.
On another note, I discovered that my old "Dyna Comp" really helps fatten up the solid state tone. It still works after about 40 years. I took the 9 volt battery out and had it storage all these years.
Again, mahalo for your response.
Mal
Aloha Brassy,
Mal
Glad to hear you take the battery out of your Dyna Comp before storing it. It always feels good when you know you saved a possible battery leak in your tools. :) Heck I've had batteries leak while using a device, very disappointing.
I built the modkitsdiy red comp "piledriver", persuader and persuader deluxe. They work good in front of the Spider Jam too.
The boost option in the settings will boost the clean model a bit, you should be able to hear it.
