tonygtr Posted May 3, 2015 Share Posted May 3, 2015 Since updating my Pod Pro HD with firmware 2.62, it will seize up in sync mode after a minute or two of editing with the latest and previous versions of HD Edit software. Has anyone else seen this issue? Quote Link to comment Share on other sites More sharing options...
silverhead Posted May 3, 2015 Share Posted May 3, 2015 Run Line 6 Monkey with the HD Pro connected. Check to see whether you need to update the USB firmware. Quote Link to comment Share on other sites More sharing options...
eljyw Posted May 4, 2015 Share Posted May 4, 2015 I have the same problem with the pod hd 500, shutdown I downgrade with the previous version of the firmware (v2.32), and all works fine. Quote Link to comment Share on other sites More sharing options...
spawn2031 Posted May 6, 2015 Share Posted May 6, 2015 Since updating my Pod Pro HD with firmware 2.62, it will seize up in sync mode after a minute or two of editing with the latest and previous versions of HD Edit software. Has anyone else seen this issue? Guys I had some issues similar to this. Doing a global reset (reboot the unit holding the left arrow) fixed the sync issues for me. Be aware that you will have to re calibrate your expression pedal after you do it though. Quote Link to comment Share on other sites More sharing options...
hemsen Posted September 17, 2016 Share Posted September 17, 2016 Friends, anyone faced with a lack of sound through VDI cable connected to the POD HD PRO? Quote Link to comment Share on other sites More sharing options...
