Can A Flextone Ii Plus Be Run Without A Speaker (load)?
3 replies to this topic
#1 N_Wallen
N_Wallen
  • 2 posts
Posted 26 April 2013 - 09:54 AM
I have a Flextone II Plus and I'm considering on removing the chassis and installing it in a smaller cabinet to function as a poor man's POD.  I plan on using the headphone jack but if I should inadvertantly power it up without a speaker connected. will that cause a problem?
Thanks.
#2 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 8949 posts
  • LocationMinneapolis, MN
  • Registered Products:2
Posted 26 April 2013 - 10:01 AM
It's not a problem running a solid state amp without a speaker connected. You'll be fine.
#3 N_Wallen
N_Wallen
  • 2 posts
Posted 26 April 2013 - 10:38 AM
Thanks.  I knew that was a general truism with solid state amps but just wanted a sanity check before I pressed on.
#4 dannyboy3
dannyboy3
  • 1 posts
  • Registered Products:1
Posted 19 May 2013 - 12:29 AM
Hi all! I have a secondary question to this issue regarding my Flextone III XL...
If Flextones are ok being run without a speaker load, can I disconnect both the internal speakers and safely connect an 8ohm cab to just ONE of the rear outputs? (This is so I can just hear the sound from the cab only - rather than one of the internal speakers still being active.)
Cheers
