I cant upgrade POd HD 500X
marcosbelial
Ok, try the following things:
  1. Make sure your POD HD500x is plugged into the computer directly. It might not be detected if its plugged into a USB hub. Even a USB extension cable could prevent the detection.
  2. Have you tried a different USB cable from the one you are using?
  3. Try a different USB port than the one you are using.
If nothing works you might need to contact Line 6 support. The good news about doing the above list is support will ask you to do them so you will already have done them.
Good Luck!
