"Known Issues" quick reference using HD Edit vs the editor in the POD
CipherHost
Using HD Edit can result it unexpected behavior compared to the editor in the POD. This tread is meant to be a resource for users to share their findings and as a repository of those anomalies. I have provided an example:
This is what I did:
Moved to a blank preset. My test preset.
Ensured the tap tempo was set to preset.
Set the tempo to 150.
Saved the new test preset.
Switched to another preset and back to the test preset. Tempo stayed at 150.
Tapped in a new tempo with the foot switch. Did not save the preset. The tempo changed to 240.
The test preset tempo was not 150 as expected, but was 240.
Where did I go wrong here?
Original Post: http://line6.com/support/topic/13848-can-i-use-preset-delay-time-and-tap-at-the-same-time/?p=98936
Unplugging the POD from my computer worked.
Set the tempo to 100.
Tapped in a new tempo with the foot switch. The tempo changed to 240. I did not save the preset.
Selected the preset again and the tempo reverted to 100.
Original Post: http://line6.com/support/topic/13848-can-i-use-preset-delay-time-and-tap-at-the-same-time/?p=98974
