Jtv-89 And Pod Hd500 - Great Rig - Now How Can You Do Wireless Using The Vdi Output?
variax pod hd500 vdi wireless
7 replies to this topic
#1 joebar23
joebar23
  • 6 posts
  • Registered Products:7
Posted 26 April 2013 - 04:43 PM
I just bought a JTV-89 to use with my Pod HD500 - I updated all the software on the Pod and Guitar and It is a great rig.  I use the VDI cable because I want the guitar setting to be controlled by the Pod HD500.  I send a MIDI Program change from my sequencer and it sets up not only the Pod HD500 but the guitar also.  I just hate the cord.  I know I can use a guitar wireless rig thru the 1/4" analog output and get the sounds from the guitar but I do not get the control of the settings like you do with the VDI cable.  It is soooo easy to save a new Pod HD500 Program with all the Variax settings and when you start your new song on the sequencer, you don't have to touch any controls on the guitar.  Any plans on wireless VDI????
Also, a while back I wrote to see if you could use the MIDI CC 7 (volume control) on the Pod HD500 and that was not implemented yet.  Does anybody know if that has now been implemented?  I would like to control the master volume of the Pod HD500 from the sequencer sending MIDI control signals.
Thanks,
Joebar23
#2 brue58ski
brue58ski
    Power User
  • PipPipPipPip
  • 1557 posts
  • Registered Products:13
Posted 26 April 2013 - 07:24 PM
This might help you get started
http://www.vettavill...e.php?id=92#402
#3 Inerzia
Inerzia
    Iknowathingortwo
  • PipPip
  • 341 posts
  • LocationSpain
Posted 27 April 2013 - 06:52 AM
Interesting...
But, does that work on the HD family of pods? I haven't seen any hint of a variax w/l mode on the menus.
Anyway, there's been some time since those posts at vettaville were published, and L6 does have a line
of wireless products now. I'm not a huge fan of wireless, but if they ever make one for the JTVs that allows
for both channels + control to be transmitted, they can count me in.
  • 1
#4 killergege
killergege
    Iknowathingortwo
  • PipPip
  • 106 posts
  • Registered Products:4
Posted 29 April 2013 - 05:08 AM
+1.
Line 6 promotes the "dream rig" AND wireless products, but the latter doesn't fully work with the former. Quite strange.
#5 snhirsch
snhirsch
    Gear Head
  • PipPipPip
  • 616 posts
  • LocationBurlington, VT USA
  • Registered Products:3
Posted 29 April 2013 - 04:09 PM
Wireless VDI would be a bit more challenging than sending analog audio.  Not the least of the issue is the need to have a return data path for control of the guitar.  My sense is that a VDI-capable wireless system would be quite expensive and have a very limited base of potential customers.
40 years of Rock-n-Roll and proud of it!
PRS Custom 24 (1990)
James Tyler Variax JTV-69(k) w/ Strat Neck
Fender / Roland GC-1 Guitar
Boss GP-10 13-pin Processor
Antares ATG-1 Autotune Pedal
Fender Mustang III.v2 Modeling Amp
#6 pheld
pheld
  • 37 posts
Posted 02 May 2013 - 03:52 PM
Wireless VDI would only be of interest to POD users, but it could be integrated in a more extensive bidirectional wireless system. Instead of having a heap of boxes and batteries on my back I'd love to have one system that combine guitar, mic (headset) and IEM. It may be relatively cheaper to add VDI to a design that already implements a shared bidirectional digital link.
#7 snhirsch
snhirsch
    Gear Head
  • PipPipPip
  • 616 posts
Posted 02 May 2013 - 04:26 PM
Hmm.  I forgot that newer hi-tech wireless rigs work in both directions for audio.  I wonder what kind of data rate and signaling is used to control a Variax?  If the bit rate is slow enough (and you knew the protocol in detail - not likely without a non-disclosure agreement) you could translate it to frequency-shift encoding like modems of yore.   Wonder if Line-6 engineering ever pondered that approach?
With enough patience the on-wire protocol could be reverse-engineered.  More work than I have time for...
But, even at that the audio path from guitar --> POD would be analog.  You'd need something like fast wi-fi for VDI digital out.
#8 killergege
killergege
    Iknowathingortwo
  • PipPip
  • 106 posts
Posted 03 May 2013 - 06:59 AM
Line 6 Wireless systems are not analog ("studio-quality resolution with 24-bit A/D conversion", "enables Relay to deliver a [...] touch response that analog wireless systems simply cannot deliver.", "encoded digital transmission technology")... So I guess transmitting VDI would be easier than analog as you don't need to perform any A/D conversion !
Hopefully the brandwidth should already be enough.
Most of the work is already done :).
Also tagged with one or more of these keywords: variax, pod hd500, vdi, wireless
