HD Desktop Output
titchyblackcat
Yes you can. Basically, setup a Dual-Amp tone and using the mixer pan controls, set pan A Left and pan B to the right....A will be your Left out and B will be right....You can also monitor that in the headphones...
Sometimes using a Digital Delay between the L and R channels set to 20ms can give it a larger sound.
Example: www.ChildrenOfTheGraveBand.com/BlackSabbath.hbe
The above example is only to demonstrate the delay between L and R channels.  Otherwise it is a hi-gain patch designed for use into the FX return of a pair of tube amps.
