pwik Posted June 8, 2015 Share Posted June 8, 2015 On Saturday night I was playing a show when suddenly my HD500X would randomly change the tone I was on. It was almost like the POD had stopped working and I was going straight to the amp (POD is connected to Line 6 DT 25 via L6 Link). If I hit the footswitch it would go back to the programmed tone for a random period of time then do the same thing again. I have all the latest firmware updates installed along with the HD amp models. Thinking of backing everything up then doing a factory reset. Any other suggestions? Thanks Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted June 8, 2015 Share Posted June 8, 2015 Suggestion: Your stuff should have been backed up LONG before now. Question: Is it possible that an audience member was reaching up and twisting a knob without you realizing it? Suggestion: Try a power cord for the pod. Question: Were you hooked up to any sort of digital device, such as midi, spdif, or L6 Link? Suggestion: Your stuff should have been backed up long before NOW. Yeah, I said it twice -- on purpose! Quote Link to comment Share on other sites More sharing options...
duncann Posted June 8, 2015 Share Posted June 8, 2015 Try eliminating the L6 Link connection and see if it still does it. Does it only do this originating from a specific patch, or any patch? If you have access to another power supply source, try that. To truly do a factory reset, you'll have to reflash the firmware, but since it's exhibiting strange behavior, I'd hold off on that. At most, you could try a global reset. Quote Link to comment Share on other sites More sharing options...
