Pod Hd400 Recording Help Needed
hd400 pod monky
1 reply to this topic
#1 VaMoose
VaMoose
  • 2 posts
  • Registered Products:1
Posted 12 July 2013 - 05:56 AM
Hi all,
So I have my desktop setup with cubase 5, and my pod hd400 set up as my audio interface.
When I record, it records the tone on the pedal, but I am unable to change the tone at a later date, how can I fix this??
Thanks,
Josh
#2 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 15917 posts
  • LocationOntario, Canada
  • Registered Products:16
Posted 12 July 2013 - 07:02 AM
The typical method of 'changing the tone at a later date' is achieved by
- recording the 'dry' (unprocessed) tone to your DAW
- apply software-based FX in your DAW to the recorded dry tone. These are called 'plug-ins' and allow flexibility in adjusting your tone at a later time. You are only limited by the scope and quality of your plug-ins.
There are two problems in doing this with the expectation of later adjustment of HD400 tones:
- the HD400 has no ability to send the dry tone to your DAW for recording
- there is no Pod HD FX plug-in
... so the short answer is - there is no fix. And it wouldn't be a 'fix' because nothing is wrong or broken - the HD400 is simply not designed to do this. Of course you can apply other plug-in FX to the already-processed and recorded HD400 tone, but I don't think that's what you had in mind.
.... John Lennon
Also tagged with one or more of these keywords: hd400, pod, monky
