grandinq Posted July 12, 2013 Share Posted July 12, 2013 Greetings! I've been puzzling with this for awhile. I want to use my DT25 to record, so I am going to mic it up. (I know I can use the cab sim direct out too, but I prefer it mic'ed up). At the same time, I'd also like to send a dry signal to be recorded. I want to use Pod Farm on this signal later. I tried using a patch I downloaded here called Wet n Dry, which I know can be used to send a dry signal when recording directly out of the POD. However, when i use this patch, all I hear coming out of the DT25 is a dry signal. This makes no sense to me, as Amp A is on. The funny thing is if I change Amp A to something else, the DT25 reconfigures itself to the new typology/class. So I know on some level it knows what is going on, but the sound of Amp A isn't there. I took the Right output from the POD and fed it as the dry signal, which worked okay. I just don't have a wet signal. I have attached a screen shot of the patch. Any sense of what I'm doing wrong here? Thanks! grandinq Quote Link to comment Share on other sites More sharing options...
