tylerhen Posted June 20, 2015 Share Posted June 20, 2015 I just connected my new HD500X to my two studio monitors via XLR. I am getting no sound to the speakers. I can't find my headphone adapter so I can't test if audio is going out at all. Just to confirm, I don't need any device between my 500X and my speakers right? XLR cables go directly from pedal to speaker? Is there a setting on the 500X where I have to specify XLR instead of 1/4 line? I just went through the setup guide and found nothing. I just tested, 1/4 gives sound. XLR does not. Thanks for any help Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted June 20, 2015 Share Posted June 20, 2015 You need a power amp. Quote Link to comment Share on other sites More sharing options...
tylerhen Posted June 20, 2015 Author Share Posted June 20, 2015 Sorry, what does that mean? I thought my speakers are the power amp. They are powered. Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted June 20, 2015 Share Posted June 20, 2015 If they are powered, then they are powered. But to answer the question of "what does this mean"... Think about a Marshall Stack. You got the cab, which is the speakers. And you have the head, which is your power amp. You can't plug your Pod straight into the cab, you need to plug it into the head. The pod does not have a powered section. It simulates the tone of amps and cabs and various mic, but it does not actually have the powered section. If your monitors have their own internal power (like a combo amp), then you don't need to worry about it. Quote Link to comment Share on other sites More sharing options...
tylerhen Posted June 20, 2015 Author Share Posted June 20, 2015 Yes they do have their own power. So why can I only hear sound when I use 1/4 line? I get no sound when using XLR output. Thanks! Quote Link to comment Share on other sites More sharing options...
tylerhen Posted June 26, 2015 Author Share Posted June 26, 2015 I tried turning the volume on everything all the way up, still no sound. Tried all switches. Guess it's just too low to hear. I'll take the cables back and get some 1/4's. Thanks for the help! Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted June 26, 2015 Share Posted June 26, 2015 you should really try all possibilities before you return anything. Could be a faulty hd500. could be a faulty set of speakers. Put the pod into something else... do you have a little recorder or something ? Quote Link to comment Share on other sites More sharing options...
robertmcollins3 Posted June 26, 2015 Share Posted June 26, 2015 I don't like using XLR anyway unless it's a long distance, which is usually not the case at home. But like pianoguy said, I'd make sure nothing else was wrong first. Quote Link to comment Share on other sites More sharing options...
tylerhen Posted June 30, 2015 Author Share Posted June 30, 2015 Finally found the little knob for mic on the back. It's very small and below something else. It's also not on the picture in the quick setup guide, and not referenced either. Strange. I do have to turn the volume way up, and I'm not sure it sounds any better than 1/4. Maybe even not as good. RobertMcCollins3, why don't you like using XLR? Quote Link to comment Share on other sites More sharing options...
AlexKenivel Posted June 30, 2015 Share Posted June 30, 2015 are you sure your XLR cable is plugged into the pod through one of the XLR outputs, either the right or left? 1 Quote Link to comment Share on other sites More sharing options...
