Delay Offset
titchyblackcat
With the spread at 100%, if you set the offset at a max of ~90%, that will give you about the widest stereo field with very little ping ponging. The more you decrease the offset towards 50%, the more difference there is between the delay times for each speaker. Below 50% sounds a little different that going above 50%, almost like the delays are the opposite of going above 50, but not quite, because the stereo field also seems a little narrower from 50 to 10, than from 50 to 90.
