jak_E_lee Posted July 2, 2015 Share Posted July 2, 2015 Since Im new to vetta I been setting up tones in the thing so over past few evenings,I have turned my thoughts to vettas fx. Im using the fbv longboard and it has the 3 switches in the middle for tremloe,mod,and delay. I have read the instructions how to save these to vetta so whats been happening,on delay(digi delay),I dial in my delay sound and press save,scroll to p3 in save mode and then select the model for digi delay at which point im asked if I want to save it as default so I hit save and that sounds saved. If I turn delay off at the pedal now after this and go back to it at a later stage,it does not seem to be saving the delay I had dialled in and saved. Where am I going wrong guys? I don't think its an amp fault as it saves everything else fine,has to be human error here? I been trying to save it on a tape echo around 200 ms,feedback around 9 0clock,tempo 140 and using the note value of 1/4 beat. Am I going wrong between note value and tap tempo as I think I read in the manual,if these are not set correct vetta returns to a previous saved delay Quote Link to comment Share on other sites More sharing options...
DickFoster Posted July 2, 2015 Share Posted July 2, 2015 Since Im new to vetta I been setting up tones in the thing so over past few evenings,I have turned my thoughts to vettas fx. Im using the fbv longboard and it has the 3 switches in the middle for tremloe,mod,and delay. I have read the instructions how to save these to vetta so whats been happening,on delay(digi delay),I dial in my delay sound and press save,scroll to p3 in save mode and then select the model for digi delay at which point im asked if I want to save it as default so I hit save and that sounds saved. If I turn delay off at the pedal now after this and go back to it at a later stage,it does not seem to be saving the delay I had dialled in and saved. Where am I going wrong guys? I don't think its an amp fault as it saves everything else fine,has to be human error here? I been trying to save it on a tape echo around 200 ms,feedback around 9 0clock,tempo 140 and using the note value of 1/4 beat. Am I going wrong between note value and tap tempo as I think I read in the manual,if these are not set correct vetta returns to a previous saved delay Remember that all the FBV settings are saved by patch. In other words if you switch to a different patch you start all over again but if you go back to the patch you saved the settings in, they will be there. You might think it's a big PITA but it really adds to the overall flexibility available. Even the on or off state and the functionality of each of the expression pedals are saved in each patch separately. Say you have a pedal doing wah wah in one patch but something else in the next patch, say delay time or volume or something else. In some ways its complicated but it's a very flexible amp which is actually one of its main strengths. Quote Link to comment Share on other sites More sharing options...
jak_E_lee Posted July 3, 2015 Author Share Posted July 3, 2015 any good suggestions to dial in a nice delay ? nothing OTT just something nice to moisten a tone for a solo. Not after a repeat delay that goes on for ever Quote Link to comment Share on other sites More sharing options...
