Connections
mjakober
OK so here is what I want. I have a Peavey JSX head and cab what I want is the amps preamp and the Firehawks FX effects. but I'm confused about the connections. Here is what I have currently.
if some can help I would appreciate it.
basically it boils down to - do you want your amplifier's preamp sound to be used in your sound via effects loop?  If the answer is no(becasue you are using the amp models on the firehawk), then just plug your left mono out  uinto the effects return on your amp, and crank the return level to 100% wet.  That will give you the true sound of the pedal without any sound from your amp.
Using the Firehawk for effects only, no modelling?
Looks fine to me. Create your patch to include the FXloop and raise the FXloop mix to 100%
