alexandresix Posted July 12, 2015 Share Posted July 12, 2015 I have trying update my flash memory (POD HD500). But everytime that I try this I got the following error: POD HD500 update failed. (Code 800900C) MIDI device timed out waiting for a response Try the update again, making sure the cables are still connected. But My cable is connected (I tested 2 cables). There is nothing pluged on computer. Just the POD Cable. I try all the USB ports. In all USB port POD HD500 driver is reconized. And my pod HD isn't working. I am with a piece of metal.. just this.. Please I need play in a GIG today and I think the line 6 will fail with me. Quote Link to comment Share on other sites More sharing options...
line-6-user Posted July 12, 2015 Share Posted July 12, 2015 Try disconnecting the USB cable, then : close everything, restart the podHD, restart the computer, make sure that thre are no programs sharing the sound card, THATS INCLUDING INTERNET BROWSERS. Plug in the USB cable, Start Monkey and retry the update. Hope this helps you. Quote Link to comment Share on other sites More sharing options...
BillBee Posted July 13, 2015 Share Posted July 13, 2015 You may also DL the flash memory to your PC then use the update from file option in Monkey. Quote Link to comment Share on other sites More sharing options...
brue58ski Posted July 13, 2015 Share Posted July 13, 2015 Do you have a Variax hooked up while doing the upgrade? Quote Link to comment Share on other sites More sharing options...
prasunc Posted July 28, 2015 Share Posted July 28, 2015 Ditto same issue with my brand new HD500 with some added excitement.... It freezes when I try to select a bank by pressing A,B,C,D buttons and after that nothing else works unless I power cycle. Then the story repeats itself over again :-( Very disappointed. Quote Link to comment Share on other sites More sharing options...
bartnettle1 Posted July 29, 2015 Share Posted July 29, 2015 Bummer man, sounds like you need to take out a support ticket. In the meantime I imagine you have tried everything, reset, what about reflashing to an earlier firmware revision? Was it working fine when you first tried it out? Did you update firmware hoping this issue would handle? If so a hardware issue and as new under warranty. If not you can open up the unit and see if you can locate a soldering fault by touch various bits with static free gloves and with the power and bits connected see if you can get the cycle to rightify itself and narrow down where it is. You might be lucky and only have to just reheat a solder joint. Quote Link to comment Share on other sites More sharing options...
prasunc Posted July 29, 2015 Share Posted July 29, 2015 Powercycled the box like I powercycle my wifi router... that seemed to do the trick! * Keep the right arrow key pressed & power on the device. * Wait for a menu to come up. All components listed with a - against them * Keep the right key pressed all this while & power down The box comes up & behaves like it should have. Surprisingly a lot of videos on Youtube say that you need to press the left key for reset but that seems to be just wrong. Pressing the left key does nothing. Quote Link to comment Share on other sites More sharing options...
duncann Posted July 29, 2015 Share Posted July 29, 2015 Pressing the left key while powering on does a global reset. After doing a global reset you'll also need to do a pedal calibration. Quote Link to comment Share on other sites More sharing options...
prasunc Posted July 29, 2015 Share Posted July 29, 2015 @ Gear Head You are more experienced than I am with the POD 500 so should I expect the display to show anything different during the reset phase. How to I know it has reset? Quote Link to comment Share on other sites More sharing options...
duncann Posted July 29, 2015 Share Posted July 29, 2015 @ Gear Head You are more experienced than I am with the POD 500 so should I expect the display to show anything different during the reset phase. How to I know it has reset? There really is no visual indication of a global reset, other than if you turned off the tap-tempo led, now it will be flashing again. If you changed any global settings prior to a reset, such as output mode, fs mode, trails, lcd contrast, etc. from their defaults, they will have returned to default settings. Doing a reset doesn't affect any presets, custom or otherwise. Quote Link to comment Share on other sites More sharing options...
bruno0fernandes Posted April 22, 2020 Share Posted April 22, 2020 My pedal was in Tuner mode on, I tried turn it of and it worked! Quote Link to comment Share on other sites More sharing options...
augshm Posted May 3, 2023 Share Posted May 3, 2023 THANK YOU On 4/21/2020 at 10:37 PM, bruno0fernandes said: My pedal was in Tuner mode on, I tried turn it of and it worked! I swear to god I tried EVERYTHING so I wouldn't need to factory reset the POD. This stupid little thing was the issue and when it worked I just couldn't believe it. Thank you so much, O Master of Minds! Quote Link to comment Share on other sites More sharing options...
