Candian_Tracker Posted July 14, 2015 Share Posted July 14, 2015 Hello! How can I see what the drive,bass,mid,treble,ch vol is before I adjust it? Want to make fine adjustments but I don't know what they are. When I move to knob, it takes on the current knob position, so I do not see what it was. Thanks! Quote Link to comment Share on other sites More sharing options...
phil_m Posted July 14, 2015 Share Posted July 14, 2015 Can't you press the Presets knob to go into Edit mode and scroll down to the AMP page to see the settings for the tone stack parameters? I don't have the HD400, but it looks like that's the way it works from the manual. Quote Link to comment Share on other sites More sharing options...
Candian_Tracker Posted July 14, 2015 Author Share Posted July 14, 2015 Thanks for the response but I do not have a tone stack parameters under amp. Unless it is somewhere else. Quote Link to comment Share on other sites More sharing options...
phil_m Posted July 14, 2015 Share Posted July 14, 2015 That may be the case then. The fastest and least disruptive way to see them would be to just turn the channel volume knob. That doesn't really affect the amp tone at all. It just changes the overall volume of the tone, and it will be easy to at least get close to where it was saved in the original preset. Quote Link to comment Share on other sites More sharing options...
spaceatl Posted July 14, 2015 Share Posted July 14, 2015 I had a 400 for a while....I agree with phil...easiest way is to just turn the knob and look where the dot is...It is not precise, but is close. If you really want to see the exact value, the best way would be to hook up to HD400 Edit application on a PC or Mac and you can simply look at the values as you change patches... Quote Link to comment Share on other sites More sharing options...
Canadian_Tracker Posted July 15, 2015 Share Posted July 15, 2015 Thanks! I guess it is an oversite but I can live with it. Was worth asking though. Would have been nice if there was a solution. Thanks everyone!!!!! Quote Link to comment Share on other sites More sharing options...
