L2M Pole Mount on Top and Bottom
I use a pair of L2M's with my HD500, and they are freakin great, but. . .
I wish you put two pole mounts on the unit, one on the bottom and the top.  I have a need to mount the units on a a pole, with a small set of lets above the speakers.  Is there physical space available for me to put a new hole in the top of the unit and install a mount?  or are there electronics in the way.
An interior photo or draweing of the unit would be most appreciated so I can make an inteligent decision on how to best mod the speakers.
Please advise.
Gorden
At least two of us have done this already
http://line6.com/support/topic/7024-solutions-for-mounting-and-lights/
I'm one of them and I utilise my L3m top mounts almost every outing (with our band anyway)
The whole mod process took me around 2 hours, doesn't involve *any* modification of the L3 speaker itself and, as with scotterp's suggestion simply uses the two existing fly-point bolts in the recess at the top of the speaker. scotterp's uses an "external top hat" https://www.google.co.uk/search?q=external+top+hat&rls=com.microsoft:en-GB:IE-Address&rlz=1I7GGNI_en-GBGB484&tbm=isch&tbo=u&source=univ&sa=X&ved=0CFQQsARqFQoTCP-e0vXajMcCFUsSLAodJAAHBg&biw=2560&bih=1408 and mine uses a block of plywood and a K&M threaded pole mount http://produkte.k-m.de/en/Speakerlighting-and-monitor-stands-and-holders/Distance-and-extension-rods/24116-Connector-plate-black equally effective.
I've run mine with both lengths of Line6 poles above, governed only by ceiling height at venues
