using lead channel and clean channel in same patch?
JeffersteinVS
Anyway to be able to use the lead and clean channel of a amp in one patch? . I hate the delay between patchs with a variax and hd500x... Im wondering if you can setup a dual amp patch and use a foot switch to switch between the two amp models so there is no delay.
Yes, you could do that very easily. There are number of ways you could set it up, but if you just wanted to have two amp models in parallel, you could set up a footswitch to toggle between them, or you could assign the channel volume to an expression pedal or footswitch.
I just noticed the amount of distortion pedals for the helix is limited. believe it or not I liked the boss metal zone model on the hd500x. Im thinking I will need to use amp distortion to get that heavy alternative/metal tone on helix.
any chance you care to elaborate on how I would set this up?
