antbass Posted August 7, 2015 Share Posted August 7, 2015 when using my g70 there is a high pitched noise present at all times in the background, i am powering the unit from my gigrig generator power supply using the distributor box (non isolated). when using overdrive or similar the noise is louder (obviously), is this due to the non isolated power? Quote Link to comment Share on other sites More sharing options...
vorphallack Posted August 14, 2015 Share Posted August 14, 2015 Power your unit with a different power supply...don't use the daisy chain....i had the same problem and that solved it Quote Link to comment Share on other sites More sharing options...
brenhaze Posted December 31, 2015 Share Posted December 31, 2015 What PSU did you guys buy?I saw the DC1-G but it shows it only outputs 200mA Quote Link to comment Share on other sites More sharing options...
WithALoudNoise Posted February 11, 2016 Share Posted February 11, 2016 Just purchased the G70 and had same high pitched issue. I was using a 9V supply with daisy chain. I switched to the USB power supply that came with the G70 and no more issues. Unfortunately, now the power supply section of my floor board looks like a giant spider. I hate freakin spiders... Quote Link to comment Share on other sites More sharing options...
antbass Posted March 3, 2016 Author Share Posted March 3, 2016 i fixed my problem by using the timelord adaptor from gigrig on my power supply, allowed me to isolate and provide enough juice from the supply i was already using Quote Link to comment Share on other sites More sharing options...
marmenta Posted July 22, 2016 Share Posted July 22, 2016 My G70 does the same thing and a separate power supply does fix the issue. I was using a one spot and a daisy chain. My G50 did not have that issue with the one spot power supply. Used it for years. Bought an isolated multi power supply for this, but don't have it yet. Hope that works too, but that raises the price point as another item is needed. Quote Link to comment Share on other sites More sharing options...
wdejong Posted June 15, 2017 Share Posted June 15, 2017 I was about to send my Relay G70 back, but then decided to check the Line 6 forums. I can confirm that the problem goes away when the device uses its dedicated power supply. It's now dead quiet, so I am keeping it! :-) Quote Link to comment Share on other sites More sharing options...
