karnifecks Posted August 17, 2015 Share Posted August 17, 2015 Apparently the search function on this forum is pretty bad, as I was only able to find 2 or 3 threads regading my issue. Some of the buttons on my X3 live have stopped working, mostly on the left side of the board. i.e. bank up/down, switch A & B & stomp. The rest work (even the tone 2 button) The other guitarist in my band has almost the exact same problem with his, so I've got to assume this is really common? Any suggestions on an easy fix? One thread suggested contact spray on the buttons and pressing the buttons repeatedly to work the spray down into the switch? Any help is greatly appreciated!! Quote Link to comment Share on other sites More sharing options...
psarkissian Posted August 17, 2015 Share Posted August 17, 2015 "One thread suggested contact spray on the buttons and pressing the buttons repeatedly to work the spray down into the switch"--- please don't do that. I will leave residue on the insides. And some of those contact cleaners are bad on plastics. Log a ticket in your account, get a return authorization. It should be serviced by a Line 6 authorized service in your area so they can check a few things. Quote Link to comment Share on other sites More sharing options...
karnifecks Posted August 18, 2015 Author Share Posted August 18, 2015 "One thread suggested contact spray on the buttons and pressing the buttons repeatedly to work the spray down into the switch"--- please don't do that. I will leave residue on the insides. And some of those contact cleaners are bad on plastics. Log a ticket in your account, get a return authorization. It should be serviced by a Line 6 authorized service in your area so they can check a few things. Thanks for the suggestion. But this thing has been out of warranty for quite some time. Unless this is an issue that Line 6 will fix free of charge, I need to find a way to fix this myself. Anyone out there have success with a fix?? Quote Link to comment Share on other sites More sharing options...
psarkissian Posted August 18, 2015 Share Posted August 18, 2015 Check with Line 6 customer support and log a ticket in your account. Your serial number may fall within range of a few things,so it should be checked to see if they were done to the unit. Quote Link to comment Share on other sites More sharing options...
taylorbeats Posted August 18, 2015 Share Posted August 18, 2015 Follow the suggestions above. If it cannot be rectified through suggestions above you will have to open the unit and reattach the green board the internal buttons sit on. They were originally glued in place (not strapped or screwed) and the glue has dried out and allowed the small push-button/green board to detach. Probably 10-12 screws 4-5 on the back of the unit, 4-5 near the bottom foot pedals. Be careful of loose parts and small springs etc. AND DO NOT PERFORM ANY OF THIS WHILE THE Unit IS PLUGGED IN. Do not skimp on a cheap glue gun or cheap glue. And do not expect this to be the first time you will have to do this. Quote Link to comment Share on other sites More sharing options...
karnifecks Posted August 19, 2015 Author Share Posted August 19, 2015 Follow the suggestions above. If it cannot be rectified through suggestions above you will have to open the unit and reattach the green board the internal buttons sit on. They were originally glued in place (not strapped or screwed) and the glue has dried out and allowed the small push-button/green board to detach. Probably 10-12 screws 4-5 on the back of the unit, 4-5 near the bottom foot pedals. Be careful of loose parts and small springs etc. AND DO NOT PERFORM ANY OF THIS WHILE THE Unit IS PLUGGED IN. Do not skimp on a cheap glue gun or cheap glue. And do not expect this to be the first time you will have to do this. Yeah, based on the research Ive done, that's what it sounds like. Thanks for the help. Quote Link to comment Share on other sites More sharing options...
