Help, Volume Lowering Sunddenly
10 replies to this topic
#1 guilhordas
guilhordas
    Iknowathingortwo
  • PipPip
  • 436 posts
  • LocationBrazil
  • Registered Products:2
Posted 18 July 2013 - 12:38 PM
my pod hd is lowering the volume suddenly, I can not figure out where the problem is, I seem to internal
Jtv 69 , pod hd 500x, suhr S3,, Gibson SG standard 96, fender plus strat 93, les paul custom 96
#2 Darkside-prince
Darkside-prince
  • 9 posts
  • Registered Products:1
Posted 19 July 2013 - 06:17 AM
I'll quote what i told the other guy with the same problem:
I used to have this problem specially when I palm muted
1-first I have to recommend u to update ur pod hd300 flash memory firmware to version 2 , if it is already re-install it , wont hurt
2-2nd What ur experiencing might be the act of The pod hd300 sound normalizer , which means ur channel is too loud and it reduces the volume to prevent amp overloads , so the solution is decreasing ur channel volume and increasing the overall (output) volume from the back of ur HD300 , this way u can both have a loud and un-normalized sound which is cool right
sorry for being so thorough but I wanted to explain completely so u could solve ur problem without any trouble if possible
so what u have to do is :
before anything update ur firmware , then if it didnt work lower the channel volume"
#3 guilhordas
guilhordas
    Iknowathingortwo
  • PipPip
  • 436 posts
  • LocationBrazil
Posted 19 July 2013 - 06:41 AM
I dnt have podhd300 , mine is pod hd500
#4 guilhordas
guilhordas
    Iknowathingortwo
  • PipPip
  • 436 posts
  • LocationBrazil
Posted 19 July 2013 - 06:48 AM
A similar problem?
my problem is during the gig, I'm playing and suddenly the sound lowers
#5 Darkside-prince
Darkside-prince
  • 9 posts
Posted 19 July 2013 - 06:54 AM
dude thats not the point just follow the instructions , use the monkey to update ur firmware , if it didnt work lower the channel volume ;)
#6 guilhordas
guilhordas
    Iknowathingortwo
  • PipPip
  • 436 posts
  • LocationBrazil
Posted 19 July 2013 - 07:12 AM
I already did the update the unit, you are saying to do it again? on the volume, you mean that the volume of the patch (amp) may be too high?
#7 evilmikehoo
evilmikehoo
    Iknowathingortwo
  • PipPip
  • 166 posts
  • LocationBrandonville, PA USA
  • Registered Products:5
Posted 19 July 2013 - 07:27 AM
Just a shot in the dark. Did you say this only happens during a gig? Does it seem to happen at a particular location? If so, could be dirty power. If that's the case, a power conditioner could solve your problem.
#8 guilhordas
guilhordas
    Iknowathingortwo
  • PipPip
  • 436 posts
  • LocationBrazil
Posted 19 July 2013 - 07:34 AM
If i reisntal the firmware Will I loose my patchs?
#9 guilhordas
guilhordas
    Iknowathingortwo
  • PipPip
  • 436 posts
  • LocationBrazil
Posted 19 July 2013 - 07:35 AM
Not during a specific gig, in any location or situation
#10 Darkside-prince
Darkside-prince
  • 9 posts
Posted 19 July 2013 - 08:06 AM
If u re-install firmware u might get a different tone so Its good to use pod edit , click on file->save bundle , this will save ur patches
but while ur at it , yeah I was talking about ur Amp volume on ur HD500 , in the Amp section of pod edit its indicated as CH VOL
lower it a little  , this should solve ur problem ;)
#11 guilhordas
guilhordas
    Iknowathingortwo
  • PipPip
  • 436 posts
  • LocationBrazil
Posted 19 July 2013 - 08:55 AM
In clean patchs , tweed amp, i use 60% in volume e15% in gain, in mixer I set in 9 db both channels
