turnall Posted September 3, 2015 Share Posted September 3, 2015 Can I connect the Spider Valve Mkii 212 directly to a computer for recording? If this is possible, please explain what is needed (detail as much as possible). I'm assuming you can via the direct connect port but just not sure how, with what cabling and if anything is needed in between the computer and amp. Thankas all, Allen Quote Link to comment Share on other sites More sharing options...
Stormtrooper12 Posted September 24, 2015 Share Posted September 24, 2015 Can I connect the Spider Valve Mkii 212 directly to a computer for recording? If this is possible, please explain what is needed (detail as much as possible). I'm assuming you can via the direct connect port but just not sure how, with what cabling and if anything is needed in between the computer and amp. Thankas all, Allen No you cannot connect the SV mkii directly to the computer like say a POD HD500 or BOSS GT-10 that has a direct USB connection. What you need to connect to a computer in your instance is an audio interface. There are many available in many different price ranges and options. You would then take the "Studio Out" XLR from the guitar amp and go into the audio interface, then interface to computer. Note that with the SV you are always supposed to have a speaker load connected at all times. Some mixers also have a USB out on them so they could also be used instead of a regular desktop type audio interface. Hope that helps a bit. Quote Link to comment Share on other sites More sharing options...
turnall Posted October 3, 2015 Author Share Posted October 3, 2015 Thanks SSstormtrooper, just what I needed... 1 Quote Link to comment Share on other sites More sharing options...
