andrearruda20 Posted September 6, 2015 Share Posted September 6, 2015 I´d like to know if I can run a 1x12 cab loaded with a 50-watt 8ohm Eminence Legend GB128 thru my Line 6 DT50 without risk. Is it possible or will it blow the speaker? Sometimes I play live and crank the volume up, but I never get it to max volume, even though, I´d like to know if it´s safe to use this particular speaker with the DT50. Quote Link to comment Share on other sites More sharing options...
radatats Posted September 7, 2015 Share Posted September 7, 2015 should be perfectly safe. Make sure you choose the correct impedance on the DT and as you said, avoid full blast... 1 Quote Link to comment Share on other sites More sharing options...
