xin344 Posted September 14, 2015 Share Posted September 14, 2015 When I am on the stage, I am very scared that if I operate any knobs or key by mistake. So is there a method to lock the key on the panel except the key by foot-press? Quote Link to comment Share on other sites More sharing options...
joel_brown Posted September 14, 2015 Share Posted September 14, 2015 Not that I'm aware of. I occasionally, while performing live, switch presets back and forth with my footcontroller to make sure none of the knobs accidentally modified the preset before starting the song. Quote Link to comment Share on other sites More sharing options...
phil_m Posted September 14, 2015 Share Posted September 14, 2015 Not quite the same as locking them, but if you turn all of the knobs to the min or max, that makes it a little less likely to accidentally bump them. At least they can only turn in one direction that way. If you're changing presets often, it really becomes less of an issue. I've never had it happen with my HD500 over the course of using it for five years. Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted September 14, 2015 Share Posted September 14, 2015 When I am on the stage, I am very scared that if I operate any knobs or key by mistake. So is there a method to lock the key on the panel except the key by foot-press? I don't think it's as easy to do that as you think. Never been a problem for me. Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted September 14, 2015 Share Posted September 14, 2015 I don't think it's as easy to do that as you think. Clicking buttons, not so easy. Twisting knobs or getting caught under the exp pedal --- can happen. Which is why my case/board repositions the input jack. BUT: 1. These are no different than any other pedal, with the exception of how wide the opening is on the exp pedal compared to my Crybaby. So, however it is that you keep the other knobs from getting twisted - that is what you do here. 2. Switching back to default is fairly easy. Just step on your switch. It re-opens your already open patch, but back the way it was meant to be. 3. How much could a cord move a knob. Your sound isn't going to be changed that much that it would ruin a performance. Quote Link to comment Share on other sites More sharing options...
sidroe Posted September 15, 2015 Share Posted September 15, 2015 I learned to keep my knobs turned off from my old POD 2.0. The Mid knob would sometimes get crud in it and the setting would switch to edit from vibration. After finding out what the problem was, I simply would turn the knob back and forth a few times and it would be fine but out of distrust I found that unless I was using the knobs it was best to just leave them turned down. Quote Link to comment Share on other sites More sharing options...
