nremondelli Posted September 22, 2015 Share Posted September 22, 2015 This is a pretty niche question for someone that owns both, but if you run the Trio through the Pod and connect the Pod to your DAW, could you record the Trio beats? Quote Link to comment Share on other sites More sharing options...
ShelbyMustangGt Posted September 22, 2015 Share Posted September 22, 2015 Is the Trio running running in front of the Pod or in the FX Loop? Then yes. Is it running AFTER the Pod: Nope, I don't think so. This is the scenario in which the Pod is your Interface. IIRC it only transmits everything in its signal path (up to your last block). Quote Link to comment Share on other sites More sharing options...
radatats Posted September 23, 2015 Share Posted September 23, 2015 yes, you can record the Trio beats through the POD. Pretty awesome pedal right? FYI, I set mine up with a dual amp patch. I run all my guitar signal through path A with a full amp model. In path B I use a preamp model to feed a clean signal to the Trio through the FX Loop. On the Trio put a dummy jack in the Amp output and feed the Mixer output back to the FX Return. Put a reverb block after that to add a little depth to your drums and bass. Put the mixer as the very last thing in the chain and center both channels. Sounds great! Sample patch - http://line6.com/customtone/tone/1118266/ 1 Quote Link to comment Share on other sites More sharing options...
Kopfschmerzen Posted September 24, 2015 Share Posted September 24, 2015 Interesting! I was thinking about plugging a guitar into Trio as it supposed to be, then send Amp out to POD's guitar in, and Mixer out to FX loop's return. No need for a preamp on path B in this case. I haven't got mine yet, though, so I'm theorizing. Quote Link to comment Share on other sites More sharing options...
radatats Posted September 24, 2015 Share Posted September 24, 2015 Interesting! I was thinking about plugging a guitar into Trio as it supposed to be, then send Amp out to POD's guitar in, and Mixer out to FX loop's return. No need for a preamp on path B in this case. I haven't got mine yet, though, so I'm theorizing. that will probably work too. I forgot I set mine up that way because I use a JTV-69 with the VDI connection... Quote Link to comment Share on other sites More sharing options...
Punkyboy Posted October 13, 2015 Share Posted October 13, 2015 ;) Quote Link to comment Share on other sites More sharing options...
Kopfschmerzen Posted November 6, 2015 Share Posted November 6, 2015 that will probably work too. I forgot I set mine up that way because I use a JTV-69 with the VDI connection... I got my Trio and finally put it to the FX loop in the beginning of the chain, because Trio doesn't bypass sound when it's turned off. I don't use it all the time, and I don't see a reason to have it turned on when I don't use it, so FX loop is a way to avoid replugging guitar cable. Trio's amp out goes to FX return, mixer out goes to the mixer. Quote Link to comment Share on other sites More sharing options...
azonze Posted May 19, 2016 Share Posted May 19, 2016 The Trio's Amp Out goes to the POD's FX Return?The Trio's Mixer Out goes to the "mixer"? What "mixer", the POD mixer?This way, it isn't better to have 2 paths? One (A) for the guitar sound and another ( B) for the FX Loop containing the sound from the Trio?And how to cable all this?I am still waiting for my Trio, the new Trio Band Creator+, with a looper. Arrives monday.Thanks. Quote Link to comment Share on other sites More sharing options...
BillBee Posted May 19, 2016 Share Posted May 19, 2016 Love the Trio myself and I like the new firmware for a "sane" bass line. :) Mixer: I believe the poster is referring to a PA mixer. Can't help much with the cabling - I'm using the HD Bean -> Trio-> D-Tech Jamman. Creating some loops to save (and pretty much screwing around). Quote Link to comment Share on other sites More sharing options...
