Help! My Pod Hd 500 And Down
4 replies to this topic
#1 alessandro-rock
alessandro-rock
  • 2 posts
  • Registered Products:1
Posted 20 July 2013 - 03:32 AM
my Pod Hd 500 dont run.. when insert cord the display become grey with white frame and doesn't work..also resetting..what can I do?
#2 deguello
deguello
  • 11 posts
  • LocationWashington - Seattle Area
  • Registered Products:5
Posted 20 July 2013 - 09:01 AM
Reload drivers through Monkey?
#3 alessandro-rock
alessandro-rock
  • 2 posts
Posted 20 July 2013 - 11:11 PM
yes but doesn't work
#4 mazuwa
mazuwa
    Iknowathingortwo
  • PipPip
  • 428 posts
  • Registered Products:2
Posted 21 July 2013 - 01:18 AM
First of all I would check the power. Can you measure 9V DC (=) output?
If you connect your POD over USB at your PC and open Monkey, will Monkey show you anything, or can HD500 Edit read your presets?
>If they can, the display would seem to be defect.
Think that a full reset also means to reinstall the firmware. Connect you POD over USB and hold down the black round multi-function button to the right side and power up. It should then boot up in Safe Mode.
Can you now read the display here?
> If you do, then continue firmware update with Monkey and finish with firmware reset and pedal calibration.
> If you don't, maybe the board is defect or the power still is not ok. Try to exchange the power cable (exactly 9V DC and at least 3A, e.g. Line 6 DC-3G). If this doesn't help, bring it to a repair center.
  • 1
#5 toneman2121
toneman2121
    Guru
  • PipPipPipPipPip
  • 2788 posts
  • Locationphilly
Posted 21 July 2013 - 04:12 AM
excellent long distance troubleshooting
I'M SO HAPPY!
