No Sound...?
troubleshooting
3 replies to this topic
#1 lancegw
lancegw
  • 8 posts
  • Registered Products:3
Posted 21 July 2013 - 02:30 AM
Help!  A speedy changeover at a festival yesterday, connected my HD500 using 4 cable method - plugged in, turned on...  Nothing....!  Ended up gigging straight into the amp.  Got home and tested all leads, amp effects loop etc - they're all fine.  Then tried HD500 with headphones - strong signal coming through...!  So the HD appears to be working - all leads are ok - amp loop is still a poss weak link but it's a Dual Rec, built like a tank, never had dramas with it...
Any ideas??
#2 bjnette
bjnette
    Power User
  • PipPipPipPip
  • 1205 posts
  • Registered Products:2
Posted 21 July 2013 - 03:10 AM
Seems like your under a process of elimination. Try another pedal or rack effect thru the power amp to rule out your first suspect.
Oh you did that. The FX loop on the HD has a send and return level. Could be that. and double check the cabling again is all I can think of.
#3 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17844 posts
  • LocationClemmons, NC USA
  • Registered Products:18
Posted 21 July 2013 - 04:18 AM
some effects loop/returns won't work with nothing in the main 1/4 input....
have you tried this with a guitar cable also in the input?
#4 evilmikehoo
evilmikehoo
    Iknowathingortwo
  • PipPip
  • 166 posts
  • LocationBrandonville, PA USA
  • Registered Products:5
Posted 21 July 2013 - 04:34 AM
Well, I AM getting old and senile, but, every once in a while - when I'm rushing to get it done - and not really paying attention..........I put the cables in reverse order!!
Also tagged with one or more of these keywords: troubleshooting
